View Single Post
  #14
Old May 18th, 2019, 15:55
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Re: 99 engine grounds
For sensors I would do a "point to point" continuity test from the sensor connection to both a "body" ground and the PCM harness.
While running or key on?
Last time I back probed the sensors and grounded to battery negative.
If a ground doesn't read on a ring terminal is this potentially because of the splice in the harness?
