View Single Post
  #5
Old March 31st, 2021, 17:00
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Questions on an 8.8 swap
Originally Posted by Wikkid98xj View Post
You wouldn't happen to remember the length would you?
Sent from my SM-G986U using Tapatalk
I dont sorry. But like i said every one is different. Lift height, spring height, trans mount condition, and angle of the rear pinion all play into that measurement.
Also donít forget to shim the axle to rotate the pinion up. When you switch to an sye the angle of the pinion needs to change to point at the tcase output.
