outlander
- Columbus,Ohio
I should have mine Monday....ill let you guys know what i think.
Well, figured I'd update you guys in here. Next sale goes live New Years Day, 1/1/17 at 12:30AM EST, 16 kits. Got a video if you like those and an ebay link but it won't work until the date above. If this link still doesn't work by then, just search up "Renix Engine Monitor" on ebay after the above date and it should come right up. My account says I'm subscribed but I have a feeling it still won't notify me so I'll try to check back every now and then.
https://www.youtube.com/watch?v=BzR0mN6xJKg
http://www.ebay.com/itm/Renix-Engine-Monitor-Jeep-Scan-Tool-/262783850744
Factory tester never showed CPS info.
are you referring to the crank sensor? or the cam sensor?
if the crank sensor is bad it will not show any engine rpms during cranking. and i also think it does not show injector pulse duration too.
there is not a whole lot of information dumped out the renix ecu.
it actually looks dulled down from what its actually capable of.
There is no cam sensor on Renix.........
What ?????
There is a second sensor in the distributor right?
That is in essence a Cam sensor right?
When it goes bad, the Renix ECU takes forever to start firing as it needs that sensor to decide if the CPS signal is the exhaust or compression stroke on cyl #1.
