Thread: Not blowing air
View Single Post
  #7
Old December 8th, 2017, 04:33
old_man's Avatar
old_man old_man is offline
Re: Not blowing air
If you can hear the motor run in the high mode only then it is probably the resistor pack. If you can hear the motor in all speeds, check to make sure it isn't coming out the defrosters all the time. If so you have a vacuum leak. If it simply does not run at all, check the fuse, then measure voltage on the motor directly. If you have voltage there, replace the fan.
Happy Hunting.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
