Thread: Not blowing air
View Single Post
  #2
Old December 6th, 2017, 15:29
ehall's Avatar
ehall ehall is offline
Re: Not blowing air
One of the more common failures is the speed dial on the HVAC control unit, the dial is known to melt and short the contacts. Not a hard repair but before you do that you should verify the fuses and motor. There is a blower motor fuse either under the hood or under the dash, I can't recall. You can also use some wire to run direct battery power to the blower motor and verify that its not seized.
my '91 beater rebuild
