Here is what I carry and where I carry it. And yes it all fits in three 8 gallon rubbermaid containers. Some of it goes under where the rear seat use to be. Everything is strapped down tightly to eye bolts bolted through the floor and re-enforced with steel plate. I use medium 1"/good quality ratchet straps. Nothing moves around on the trail
Center console
Mini Mag Lite and extra batteries
Tire Gauge
Bug spray, sun-block
Spare Fuses
Swiss Army Knife
Staun tire deflaters
In door pouch
2 Ponchos
Recovery, stored in the right rear fender area
2 pieces of Plywood 12”x12”, for jacking in the mud/sand
2 10” long 2x4's
Folding Shovel
3"x6' Tree Saver Strap
3"x30' Snatch Strap
Gloves
Assorted D-Rings
Tool s (in a 8 gal Action Packer)
BFH
C-clamp
1/2" Drive Socket Wrench
1/2" Drive 15-22mm, 24mm, 32mm, 36mm Sockets
1/2" Drive 3/8"-1" , 1 1/8”, 1 1/4” Sockets
1/4" Extensions
¼” drive socket wrench
1/4" Drive 7-10mm Deep Sockets
1/4" Drive 1/4"-5/16" Deep Sockets
7-23mm Combination Wrenches
1/4"-1" Combination Wrenches
Hack Saw w/extra blades
Large torx 40, 45, 50 Sockets
Spark Plug Socket w/swivel
Pliers
Channel locks
Medium size pipe wrench
Needle Nose Pliers
Vise Grips(small, large and needle nose)
EMT Sheers
Side cutters/dykes
Adjustable Wrench
1/2" Drive Breaker Bar
1/2" Drive Extensions
1/2" Drive to 3/8" Socket Adapter
½” drive swivel
3/8" Drive 10-14mm Deep Sockets
3/8" Drive 3/8"-5/8" Deep Sockets
3/8" Drive Socket Wrench
3/8" Drive 12 point 8-19mm Sockets
3/8" Drive 3/8"-3/4" Sockets
3/8" Drive Extensions assorted(you will need enough to put together to reach the CPS)
3/8" Drive to 1/4" Socket Adapter
3/8" Drive to 1/2" Socket Adapter
3/8” drive swivel
1/4" Drive to 3/8" Socket Adapter
Tubing cutter and flare tool and flare fittings
10mm-19mm swivel sockets
6 pt 8 mm box wrench, 12 pt 8 mm socket
Small prybar
Punches, chisels and alignment pins
Channel locks, large/small
Feeler gauge
DVohm meter
Test light
Wire crimpers and assorted connectors/extra wire
OBD2 scan tool
Metric Allen Keys
SAE Allen Keys
1/4” drive swivel
Flathead Screwdrivers
Phillips Screwdrivers
Torx Screwdrivers
Jumper Cables
D-Cell Mag Lite and extra batteries
In left rear cargo area
Fire Extinguisher
10 ton Bottle Jack
CO2 tank
ARB Compressor and hose
FLUIDS (in 8 gal Action Packer)
4 Qts. of Oil
4 Qts. of ATF
1 Gallon Potable Water
Screw on pour spout
WD-40/PB blaster
Fix-a-Flat
Brake fluid
Spare parts (under rear seat and in rear floorboard) or in 3rd action packer
Spare U-Bolts
1 Spare C8.25 29 spline Axle Shaft
1 Spare Tie Rod w/ TRE's
Broom handle to push out broken shafts
Spare F/R yokes
Spare Driveshaft U-joint
Spare Nuts and Bolts
1 Spare XJ front drive shaft(can be used front or rear with my SYE)
1 Spare Serpentine Belt
1 Spare Fuel Pump
1 Spare IAC
1 Spare CPS
Spare relays and fuses
2’ of 10,12,14,16 gauge wire
Electrical tape
Haynes Jeep Cherokee Repair Manual
Small Grease Gun
Duct Tape
Spare Valve Stems
Tire Repair Kit
Garbage Bags
Vaccum Line Repair Kit
Hose Repair Kit
Spare U-joint Straps
Spare Lug Nuts
2 Spare Leaf Center Pins
Assorted Spare Hose Clamps
1 Spare Diff. Plug
1 Spare U-joint C-clips
Spare Snap Rings
Right Stuff sealant
JB Weld
Spare unit bearing mounting bolts and cotterpins
3’ of 3/8” tranny cooler hose
2’ of ¾” heater hose
2’ of 5/8” heater hose
2’ of 5/16” FI hose
2’ of 3/8” FI hose
Hose mending fittings of all sizes
Zip Ties
Towel
8’x10’ tarp/4 spikes
First aid kit
Spare Tire in rear floorboard held down with the hilift and straps
Small resealable drain pan, 8 quart
