Smash Hole
GFY
- Smash HQ
Well I got $58 of bilstein parts coming.. Hope this gets the back end sorted out otherwise I'm switching shocks. $58 is insane for some shims and two shaft bumps.
I almost joined the burnt to the ground club...
mac 'derale wiring leaves something to be desired' gyvr
Wife, baby, and I went back up to WI this Saturday, this time to Two Rivers to see her other Gpa
Should have said something, I am in Sheboygan 1/2 hour south of Two Rivers, you drove past it both directions...
Spent the weekend up in Lake Geneva for my wife's family reunion. Good times. Good people.
We set up tent with other family members in grandpa's backyard. My air mattress went flat and I had to sleep on the ground with the baby next to me. Add a case of beer before hand and you have a rough morning.
But
They had A LOT of thick cut bacon as soon as I was up.
Going back to WI this coming weekend. This time to Two Rivers to see her other grandpa. We may make our way up to Door County. Not to sure yet what he has planned, but I know he loves it up there.
L.e.d. taillights just wont work, I think the tow ready box is bad I have quadruple checked all connections and everything works except for the brake only flickers briefly. Started a thread about it in Mod tech but I may just rip it all out and try to wire it from the stock trailer wiring and throw out the "tow ready" converter.
What a Pita this has been.
I should have put a little more effort in selling this.
I took the ad down and it is back at my place again.
I am going to put some fender flares on it, clean the fuel system even find a good used set of tires for the front.
I have been working 7 days a week and I have not put much thought into it.
Do you have the polarity correct on the lights?
I replaced one of the 3-2 converters recently.
Checked the inputs to it, brakes worked, signals did not. Just a bad box.
Mine went bad after Moab(probably when the turn signals quit because of a short), while I was wiring the LED's on the trailer I found that out. Replace it, they are cheap on Amazon.
Only As of a few years ago. It used to be really complicated. Now it's Almost too easy.Iowa is awesome. Quick NICS check and 55 bucks, then out the door.
2011.
Yes, it is almost too easy. I wouldn't be against them making it a little stricter.
