View Single Post
  #4
Old July 14th, 2004, 23:26
4xBob 4xBob is offline
Re: water instead of oil...
When you opened the transfer case and only found one drop of oil (actually Dexron II ATF), was that the bottom one (drain) of the two plugs? OK if this result was from opening the top threaded (filler) plug!! Sorry for asking the obvious....
