MiWiAu
- Milwaukee, WI
TL/DR: If I went with E load range tires for my XJ, how much would I compromise off-road traction and on-road ride quality to gain sidewall durability vs going with a Standard/P load range? Is it worth the tradeoff?
Hey all,
I know tire questions are never-ending, and I have more of them. I’m new to the Jeep/off-road scene, so I don’t have a background in off-road other than some m/c trail riding, but I have been trying to research and these are the questions I’m still left with.
Vehicle Background
I have a 98 XJ, and I’m looking to upgrade to 31” tires to fit a set of 16x7 Jeep Icon wheels. It looks like my main options are a 265/70R16 (my strong preference due to the extra width) or a 245/75R16.
My intent is to build this thing primarily as an overlanding vehicle and be able to eat up some highway miles on the way to some more scenic trails. I’m in SE Wisconsin, and not sure of many (any?) trail options that are local to me, so travel will be required. I may want to do some more moderate stuff at the off-road parks, but I’m looking to make it an adequate all-around performer, not specialized for any single type of off-road. It is definitely a project vehicle and NOT my primary mode of transportation, so that affords me some flexibility, but ultimately, I want a good balance of on/off road performance.
The questions…
Is there a good way to determine whether or not a tire is designed to run aired down without contacting a manufacturer and/or is there a list of currently available tires that fit this criterion? One recommendation I found in my research was to purchase a tire specifically designed to run aired down. The description for the BFG KO2 mentions “additional traction…during “aired down” off-road driving,” but they are the only ones I ran across that specifically mention airing down.
With the added sidewall stiffness of an E load rating, do you really even see much benefit in airing these down on a vehicle as light as an XJ? It seems that the benefit to airing down is to increase the contact patch and improve conformability to terrain, but if the carcass doesn’t flex due to a super stiff sidewall, how big of a compromise is the E load rating to traction? For Standard/P load range vs E, it seems that the tradeoff here is potentially conformability/traction when aired down vs sidewall durability.
Are there any Standard/P rated tires for lighter vehicles that are known for good sidewall durability off-road that provide less of a compromise to on-road ride quality? I see the Goodyear Wrangler All-Terrain has Kevlar and is available in both standard and E load ranges. It would be nice to save the extra weight from an E tire, if the standards won’t leave me stranded.
If I run a 265 tire on a 7” rim, any suggestions on lowest tire pressure to run to prevent my tire from coming off the bead? For most of the 265 tires I've found, 7" is the minimum "recommended" rim width. Obviously, I wouldn’t be running bead locks with the Icons.
Hey all,
Vehicle Background
The questions…
