View Single Post
  #6
Old November 3rd, 2019, 20:48
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Re: 98 won’t start
Have you tried another battery, or do you know for certain this one is good?
If A4 has ground and A17 hasn't any voltage at all, I'm a bit inclined to lean towards the pcm. your voltage gauge not reading anything is a bit suspicious as the pcm should still read this if it were a sensor, No?
Do you have access to a working pcm?
