Thread: Booster Upgrade
View Single Post
  #79
Old October 10th, 2021, 23:58
azzy89 azzy89 is offline
Booster Upgrade
Originally Posted by giacomo.m View Post
Thank you azzy89
I will try to loosen the brake pedal bolt, and what problem could happen if i used the white switch for the brakes lights ?
Giacomo
Well if something gets wired wrong you could potentially fry your TCU. But if you use it just as a switch it should work fine. Also keep in mind the brake switch is replaceable, I believe the TC switch is JY only.
