View Single Post
  #5
Old July 29th, 2021, 18:56
tech1001 tech1001 is offline
Re: 92 High Fuel Pressure/Stinks/Runs Rough
Also use a air hose and blow out the return line just to make sure it not plugging up . The fuel pressure regulator has a spring loaded needle and seat with a vacuum diaphragm that pulls on the needle so when vacuum is applied it pulls on the spring and lowers the fuel pressure .
