bimmerjeeper
- USA
My cables were very corroded. Even the bolts were frozen solid. I replaced them today.
I decided to spend some time writing this up in the style I find most useful.
If you like this better than "Disconnect all wires. Replace new wires. Drink beer!" then let me know.
Yea, for most guys here, this job is too basic to bother writing up.
I am new to working on cars, and need all the details and photos I can get.
Also, I like to know what I am getting into before I try to tackle a job.
As you all know, there's always a few gotcha that can ruin you.
Hopefully, this post can help other new guys who are wondering if they can replace their cables by themselves.
This job was suitable for a beginner. Nothing got stuck, and it was just turning bolts. It took me a couple of hours.
This is because on a new project, you spend a lot of time figuring out what you're looking at, and what order to do things in, etc.
If I did this again, I could do it in 45 mins.
BEFORE
I ordered a set of 4AWG cables for $80 from Jon at http://www.kelleyswip.com/price.html. They were precut to my year of XJ.
He answered all my questions patiently. (And I had a lot, believe me) I felt good about sending my business his way.
He is a good man, and any 1-man shop is a labor of love that involves countless investment of time for minimal payback.
The 5 cables are as follows:
Tools needed:
All bolts came off with no problem. I did use PB Blaster just in case. My battery cables needed to be pried off with a long screwdriver. I used all metric sockets and wrenches (8mm, 13mm, 14mm). I also used wrenches for some tight fits where a ratchet head would not fit. Be patient here, b/c you might only get 1 or 2 clicks on the ratchet with each turn. I got a pillow to rest my neck while undoing the blots 1/8 turn at a time! I also used a 3/8" wrench for the fender ground wire.
BEFORE
- (+) to Starter Motor
- (+) to fuse box/PDC
- (-) to Engine Block
- (-) to Fender
- Braided cable from rear of Engine Block to Firewall
Tools needed:
- Metric and SAE sockets and wrenches
- Long flathead screwdriver (to pry off battery posts)
- Utility knife
- Dielectric grease (for all cable connections)
- Wire stripper (optional)
- PB Blaster (optional)
- Heat gun (optional)
- Electrical tape
