September 23rd, 2006, 23:28
Re: 02 sensor code....Bank 1, Sensor 2
Originally Posted by Ben H
On my 2000 there are 2 fuses that have given me PO135, PO138, PO141 codes. When I first pulled the codes I replaced the sensors to no avail, then found out about the fuses. (I have an excuse on the 2000 it is nearly impossible to find a fuse diagram without a FSM). I don't know what year you have but....
check your fuses first.
What do the fuses control? I havent run into this before and the more knowledge the better.
