View Single Post
  #4
Old October 12th, 2010, 13:19
jeepme's Avatar
jeepme jeepme is offline
Re: Random but need Chryco 8.25 pinion yoke
instead of using the u joint straps it uses the 1310 u bolts. Much stronger.
http://www.dennysdriveshaft.com/p340...30_series.html
Clayton long arm lift, F250 D44 front with RCV shafts, Currie 35 spline 9 inch rear, 37's, ARB's, OBA, Rubi T-case, Accutune Fox shocks, Radesigns manual shifter, yada yada yada.
