- Aurora, Colorado
Part 1
Well, push came to shove and I decided it was time to ditch the 242, and upgrade to a different T-case. I wasn’t interested in hacking up my tunnel, or dropping more than $3000. With the help of DJ, I chose the NVG241OR Rock-Trac from JB Conversions. After a lengthy E-mail conversation (determining whether the case would have enough spline engagement between the trans output and the T-case input,) I had one brand new 241 with 1310 Yokes installed Front and Rear on its way via Fed-ex freight to me for a little over $2100. By the way, the folks over at JB are awesome. Customer service is great, and I couldn’t have asked for better service.
Few Pictures right out of the box:
oOoOohh Shiny
Anyway, I wanted to make sure I did this right. I didn’t want to get it up there, change my mind, and drop the case again. Ideally, lift it once and keep it up there for a while. This T-case weighs right around 100 lbs. It’s not easy when you don’t have the appropriate jack to hold it in place. My rig will be Daily Driven until I can afford another mode of transportation. This means I want the Speedo to work, and I want the 4 Wheel Drive Indicator Illumination to function properly as well. JB sells a wire/switch set to make the 4WD Indicator to work. These pieces are customized for the 241OR application.
For reference – There are 3 wires (on NP242 models, 2 on NP231) coming from the harness, to the connector.
Black/White – Full-Time signal
Black/Red – Part Time signal
Black – Ground Distribution
Word on the street is the 241OR has a bit of a sweet tooth, so I picked up some liquid candy for it.
Now. A case that’s designed to handle to power output from a Cummins Diesel Motor; Maximum Torque Capacity: 5,555 ft lbs vs. 1,885 ft lbs with the NV231, and 1,486 ft lbs with the NV242(; 4:1 crawl ratio; 32 spline output shafts; and a direct bolt up… Could it get any better? How about 4:1 2 Wheel Drive?
Yep. Teraflex now makes a 2-Low kit, for the TJ 241OR. That install will be covered in the next reply.
Scott
Note: Above numbers regarding Maximum Torque Capacity were referenced from Eric Zappe's (EricsXJ on ) book - "High-Performance Jeep CHEROKEE XJ Builder's Guide 1984-2001."
JB is an NVG aftermarket distributer, and buy these cases straight from the plant. The metal tags are not installed at the point at which they are purchased.
oOoOohh Shiny
Scott
