3.5 inch lift
No matter how much prep and PB Blasting you do, I’d have a plan b for work Monday morning. There’s always that one thing you weren’t expecting. Good luck, XJs are a ton of fun.
Wow, a clean stock Briarwood. It's already a classic, going to be more desirable in the future cleaned up and made mechanically perfect. If you start modifying that classic, some years down the road, I suspect you will regret it.
I did the RE 3.5 last year in mine. You can get the kits with track bar, different shock packages etc. I did the short arm super ride setup with quick disconnects also. You will probably need a SYE also. I have been very happy with mine and my use is similar to what you described.
Is it common consensus that an SYE is necessary for a 3.5in lift?
I was hoping if I kept it at 4in or lower I could avoid that extra cost.
What say ye NAXJA?
What say ye NAXJA?
It's more dependent on the year.... 97+ are very likely, to 97 not so likely
In my 1997 and 3.5" I had to do a t-case drop. I had bad vibrations from 50-60mph. I used the Rusty's crossmember that incorporates a 1" drop and it solved the issue. I've got a SYE in my parts bin waiting to be installed.
Every one of these tends to be different, though it is true that in general the earlier (pre-96) models tend to be a bit more tolerant of small lifts in terms of vibes. 97+ (and any 96s that have the 97+ tcase design) will be less tolerant.
My '92 showed vibes when I put the original 2-inch lift on it, had to have a 1" tcase drop added. However, I've gone from that original 2 inches all the way up to 4.5 and not had any further vibe issues, even with a stock rear shaft.
How long has it been since your driveshafts have had new ujoints installed? If it's been a good long while, you may find vibes just by the lift changing shaft angles and altering the wear patterns...
Interesting, thanks guys.
I've got a 99 so it looks like I'll need to plan on biting the bullet and doing a SYE at the same time as my lift.
that is a great looking rig, I love the briarwood / xj wagoneer!
don't cut up the body for tires! I had a 3" with no SYE, drop pitman or tcase drop and didn't have any suspension issues as a DD.
I have a 2000 xj, with the RE 3.5 lift, full rear spring kit also from RE, and beefier tie rod. Riding on 32s. On my daily driver. I like the kit a lot, easier to install than a long arm kit for sure (I'm not crawling or going super fast through the desert). It gets me where I want to go. Make sure you know about death wobble issues and how to correct it if you are installing yourself (for me it was mostly caster adjustment). Also a steering box brace would be helpful, I kept stock pitman arm, steering box ended up leaking a few months later, replaced box and put in a brace.
Sent from my SM-G965U using Tapatalk
