    More Information - Join/Renew
$100 Off Serious LongArms
Can I get a copy of the install guide as well? Thanks!
Got any pics of these installed on an XJ? Seriously considering Serious Offroad.
Here ya go...
Some action pics, cuz I know you wanna see 'em.
RiderGoatee (NAXJA)
RZOSeth (NAXJA)
Helluva kit(and price), but I wish the chassis mounts were tucked up inside the frame rails for more clearance. I've seen a kit like that and thought that was a great idea.
I want. Looked at a lot of LA kits out their, think yours takes the cake. But would def like some install instructions a few people asked for above if you don't mind...also if it's not a hassle a phone #..LOL kind of ridiculous I have to ask but I don't get off work until late at night and my work's internet won't let me access your site...damn newtork filters
Installation is very straight forward.
The condensed version:
Remove the OEM crossmember and using the same holes in the frame rails, secure the new crossmember.
Drill 2 holes per side through the frame rails.
Measure the distance between the LCA bolt holes and the long arm mount at the cross member. Use this measurement to set the length of each arm. ( Do one side at a time. )
Install the lowers and adjust the radius arms (uppers) to mate with your UCA mount. Repeat on the other side.
After that you cut off the frame side LCA mounts.
What's included in the kit:
Crossmember, Upper and Lower arms, joints, backing plates, all of the hardware needed to complete the installation.
Nothing else to buy.
HTH
