    More Information - Join/Renew
rock rail Qs
rooneypower
Woodinville, WA
Is there any lines i shouldknow about in the sub frame of an XJ before i drill the holes to mount my rock rails?
Also, what size bolts should i use for mounting it to the frame?
Thanks
userbmx1315 said:
the fuel lines on the drives side
Those lines are not contained or hidden inside the "frame rails".
They are however to the inside of the frame rails. That sounds really confusing. :huh:
It shouldn't be though- you can see the fuel lines, they're mounted on the exterior of the frame rail, towards the inside of the Jeep.
