NAXJA is having its 18th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
Hey so im working on my A/C to OBA set up and im having troubles finding a AC compressor, I was just wondering what other AC compressors can I use? Making my own mount wont be hard.
So I could run any A/C Compressor that works with our serpentine belt? But is there any other stock Compressors that work better then others? I was also planning on running a Tool Oiler on the intake line and a water / oil separator on the out put line to the tank.
yes you will need both i highly recommend going with the york thats what i have on mine and its the best. plus you can get one cheap at a junkyard got mine for 29$ also check out kilbyenterprises.com
If you go with a York compressor you will not need an inline oiler and if you make your own brackets it will be fairly easy. You can get a pulley for the alternator that has serpentine to drive the alternator and a v-groove for a belt to drive the compressor. That way you save money on an expensive serpentine drive clutch for the York. The pulley can be bought from Kilby Enterprises.
Sorry for the high jack but was wondering what you guys would think is the best viair compresser for a tank just under 3 gallons the 400C with 2.54 cfm flow vs the 450C at 1.66 cfm. I would like to be able to run an impact gun thanks.
