View Single Post
  #2
Old February 17th, 2019, 23:01
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: head light upgrade?
Originally Posted by POSrenix View Post
anyone have any input on headlight upgrade with the recent rain mine are not up to par
Upgrade the headlight harness first, the Factory wiring is inadequately sized. You will see an immediate increase in brightness.
Upgraded headlights range from Sllverstars, to a variety of LEDs in a wide range of price and quality. Others can comment .
With upgraded wiring, H4 housings can be used which have a sharp low beam cutoff, allowing higher wattage bulbs to be used.
I have run IPF housings for years, along with Hella 80/100-watt bulbs.
https://www.quadratec.com/products/97017_1600.htm
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
