Renix woes for 1988 XJ 4.0/auto
ok so reply and this is fixed.
i finally worked it out. and i got the REM from Nickintime on YT. you can view all your sensors live and scroll thru them and see what your engine is doing. best 100 bux i ever spent in this mess.
my advice for noob Jeepers with a Renix; get the REM; and things to watch for --head to intake and exhaust gasket. tps and fuel pump and the engine harness. if you have harness issues, get one from a junkyard. not easy to replace, but is do able. it is a separate harness from the main. from the CPU to the engine . and follow Cruiser's ground clean up
