notamechanic
- Orange County, CA
Went to install a powertrax no slip tonight and ran into this issue. My pinion shaft will not clear my ring gear and therefor I can’t remove it/remove spider and side gears to install locker.
Any tricks for installing this? Possible to install the locker without removing the pinion shaft? The person who installed my gears ground the center of the shaft to clear the c-clips for axle shaft removal. But not enough to get the thing out. Really don’t want to remove the whole carrier/ring gear to install a lunch box.
