    More Information - Join/Renew
XJ Buildup III
hman333 said:
where did you get 2.5" x 6"
The 2.5 x 6 Tubing Store?
I really don't recall.....could have been 4"? Scored it at the local Metal Supermarket.....really.
coastie124 said:
That's a good looking rig there man. Can't wait to see some good flex pics. I really like those moabs with that color XJ. Looks sharp.
Thank you all for the compliments. I really liked how the Moabs worked on my last XJ, the 285/75/16 is a good fit for an XJ wheelwell, too.
Made some progress last week on the beefed HP 30.
Got the ball joints installed and was surprise how well my cheap HF press worked.
SBS Plate welds smoothed, primed and finished.
Closeup of the RE SuperRide bushings used in the TnT truss
Trimmed stock shock mount, LCA gusset and new shock mount placement
Was curious... Did you source the Super-Ride bushings? Why those instead of Super-Flex?
I asked Bob at TnT about the bushings before ordering. He indicated that the SuperRide units perform well and hold up to flexing too, so I'm going on of his recommendation. They ship all the Y arm kits with these at the axle end and Summit flex joints at the crossmember.
Gojeep said:
They are not un-graded coach bolts in the shock mounts are they??
Good eye! Must be just for mock up.
Been busy this summer, lots of weekend trips with the fam........none offroad though :( . Here's some stuff that I've gotten done.......
Looks like the Server crash bumped my updates, so I'll repost.
LCA Skids and gusset shot
Vanco Dual Piston caliper upgrade, Alloy axle seals, Alloy 30 spl shafts and Goferit knuckle insert for OTK TRE
looks awesome, man. Very detailed work.
I took those little rotor protector plates off mine because they trap gravel and make horrible noises...
