View Single Post
  #58
Old February 3rd, 2019, 09:21
Heavyopp Heavyopp is offline
Re: Engine swap vs shop
I wouldn’t try to weld a nut on if it’s broken deeper than the threads
I’d drill it all the way thru if possible — It's probably not bottomed out in the hole
Then heat it with a torch, till is red, then cool it fast with wd40 — it should back out now with the not so easy out — I’ve had success with exhaust bolts doing this
