View Single Post
Old June 3rd, 2016, 17:42
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
Shifter interchangeability early/late?
So I was doing a search and didn't find much on this matter just the bezel and other tidbits.
But can you direct swap a late model aw4 shift lever that is inside over to a early model? With my 91' I'm seeing how the straight shift lever can cause my knuckle to hit the center console but in my 97' the shift lever is curved and a bit easier to use. If it isn't direct swap what would be needed to swap it over? Might as well fill my curiosity if I ever chooses to swap it.
