View Single Post
  #3
Old October 8th, 2021, 19:42
JerryG11 JerryG11 is offline
Re: Crank No Start/No Fuel Pressure
Thanks for the response!
I checked the current. With the key switched on I get a reading of 1.5 amps. This is the same if I jump to the pump from the battery and also if I try starting. Energizing the circuit also gave me no change in the fuel pressure. In wondering if I got another dud pump, I broke down and ordered a bosch replacement just in case.
Could I be missing something? I know the line isn't closed or anything. I syphoned fuel through the rail connector
