Thread: Booster Upgrade
View Single Post
  #9
Old October 10th, 2017, 13:02
Green XJ Jeep Green XJ Jeep is offline
Re: Booster Upgrade
Dual diaphragm from a 95-96 XJ is you best option for an easy bolt on.
WJ will work but need some modifications.
If you go the WJ route make sure you get the brake lines from master cylinder to proportion valve. You will need the ends to make new lines.
