View Single Post
  #59
Old April 13th, 2019, 09:16
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Another death wobble thread
Originally Posted by cherokeecrawler View Post
I had bad deathwobble at about 65, especially when i had absolutely nothing in my jeep. Shoved my lower fixed arms as far forward as i could and put some weight in it and it was completely gone. This may not be your problem, but as some other people said, diffidently worth looking at a good bit.
Adjusting the LCAs to be longer, without checking the caster or the front driveshaft's u-joint pinion angle, is recipe for failure.
The added caster helps stabilize the suspension, but as pointed out, it's a band-aid, there is something(s) loose.
Too much front pinion angle can lead to vibs and pinion bearing damage, it's supposed to set at between 1/2 and 1 degree.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
