View Single Post
  #3
Old December 1st, 2017, 19:26
Slimer Slimer is offline
Re: Blew the Reservoir on NEW Power Steering Pump!
Turned out to be a bad pump. I took the reservoir off and hooked to my air compressor electric motor and ran hydraulic fluid through it. The low pressure side or the return side had over 250 psi while the high pressure side only had 36 psi. Maybe they rebuilt it backwards, I don't know. I exchanged it and the new works fine. Strange.
