speedo gear sleeve and gear torn up
sartor
arizona
Hi all -
Any ideas as to what could cause this?
Highway driving and speedo/odo quit and threw the P0500 code. Had a guy pull the SYE tail housing off and he found that the speedo gear and the gear sleeve were both chewed up all the way around.
No other symptoms.
Put a new gear in and turned the sleeve around (because only 1/2 of the sleeve's gears were chewed up. Speedo worked for about 20 miles then quit again. I'll be we find another chewed up gear/sleeve.
What kinda vehicle ? A P0500 hints at OBD-II ?
Is the speedo sensor correctly indexed ?
Select the appropriate tooth gear range you just installed and rotate it until it is aligned with the raised dot on the transfer case as shown in the pic.
Forgot. :)
1998 XJ 4wd 4.0
4.56/32”
Also if note, that speedo gear probably had 20,000 miles on it.
Is it possible for a VSS to fail in a manner that would prevent the speedo gear from spinning, and would then rip up the teeth on the sleeve?
It was. It worked for a good 20k.
looks & sounds like the sensor side of things locked up..........or if it had a cable, I'd say it seized.
That's what I was thinking. Wondering if it is even a possibility. A friend said that sometimes there may be a T-case shaft misalignment and it's putting pressure on the speedo gear and sleeve causing it to get chewed up. However, I have zero other symptoms.
Curious.
The gears have a lash adjustment by rotating the housing to compensate for gears with different numbers of teeth. Sounds like someone either got it way too loose or way to tight.
Interesting. I did not know that. I changed gears 3 times by pulling the gear and the little shaft out, pushing the new gear and attached shaft in, re-inserting everything back into the transfer case housing and bolting it in its original position,... the two groves cut into the base plate. Because of its design I take it for granted it would not fit any other way.
