View Single Post
Old December 2nd, 2021, 16:55
DrSockMonkey's Avatar
DrSockMonkey DrSockMonkey is offline
Alternative spring packs for big lift.
I have an 86 MJ long bed with a SOA Dana 60 rear and running 37's. The current configuration is unknown spring packs, 4" blocks and 2" shackles. I want to get rid of the block, or as much block as possible. I also would like to add 2" of lift to the rear as it's 2.5" lower than the front. From center of front axle to bottom of stock fender flare is 31", the rear spacing is 28.5". Happy to hear of vendors who sells packs too. I have done searching but MJ's use different packs than XJ's so I didn't see a lot. Thanks in advance for any help.
