View Single Post
  #6
Old August 14th, 2019, 10:39
notamechanic notamechanic is offline
Pinion shaft not clearing ring gear.
3 things to think about: First - fire your gear guy.Second - it got put together somehow. Third - you can't remove the carrier w/o first removing the shafts.
Work was done by premier west gears here in SoCal. Not sure if anyone’s heard of them.
I can luckily at least remove the shafts due to the installer who notched the center pin. Just can’t get the spider gears out without removing the center pin. Pretty frustrated, this was sort of the last big install to do on my Jeep. There’s always something...
