View Single Post
  #2
Old May 2nd, 2013, 14:37
XJsportG's Avatar
XJsportG XJsportG is offline
SouthEast #4328 (RVA)
Re: VA- Big Levels / Stony Creek Jeep Trail (FS 162)
1) The burned out Hippie bus is no longer there. Someone took a plasma cutter about a year ago and took it apart in multiple trips. Not sure if it was Park Service or someone looking to make a buck.
2) The GPX is not 100% accurate. The north part of the trail that goes up the mountain is not legal. The legal trail is switches back which can be seen in the first picture.
The second is screenshot for the Motor Vehicle Usage Map 2012 (MVUM) for GWNJF.
Need to make sure you stay on 162(main trail), 162A(Cold Spring/Bald Mountain Trail) and 162B(Kennedy Ridge)
MVUM can be found here. Map 27 http://www.fs.usda.gov/Internet/FSE_...rdb5392127.pdf
