Lincoln Versailles(Ford) 9" rear end, 58.5" wide, 5x4.5 bolt pattern, discs $700 OBO!
Safari Ary
This is the rear axle from a Lincoln Versailles.
Hey everyone, haven't been around here in a while, but I have this axle for sale and it is almost ideal for an XJ.
It is a Ford 9" rear end with factory discs.
The rear axle is 58.5" wms to wms with 5x4.5" bolt pattern.
Swap this into your XJ or MJ and never break your rear axle again.
I don't know what the gear ratios are, but they are very tall, so you'd probably wanna swap them out.
Axle is located in Blacksburg, VA, but can be delivered to the DC area or NC relatively easily.
$700 OBO(seriously, make me a REASONABLE offer)
Ary
Re: Lincoln Versailles(Ford) 9" rear end, 58.5" wide, 5x4.5 bolt pattern, discs $700 OBO!
Off topic but what is fords model on this?
Andrew
I honestly have no idea what the Ford counterpart is. Sorry
After a bit of searching its the gernado(sp), what is the spline count, and is it big or small bearing?
Andrew
It is 28 spline, and IIRC does not use standard "small" or "large" bearings. I do believe moser, dutchman, etc offer 31 and 35 spline axles for this application though due to it's swap popularity. Not positive though.
We bought this axle for my uncle to use in a Lotus 7 w/ an LS1 for an engine, but decided to go another route. This was pulled from a running/driving car and is complete.
Ary
Bump!
New price $550
