Sagging Springs
I've got some weird sag in my springs. A sagging rear isn't suprising, but I'm a little concerned my drivers side is about 1/2" shorter than the passenger side. Here are the measurements of the bottom of each fender flare to the ground from the wheel centerline:
drivers front: 30.75"
drivers rear: 30.5"
passengers front: 31.25"
passengers rear: 31"
Is a sagging drivers side normal on XJ's, or are my drivers side springs more worn out than the passengers side? Is there an easy fix for this, or is buying new springs the only way to fix the problem? Has anyone else experienced this?
