gearwhine
- Denver, CO
since I've worked on this for a few years, done a few things, and plan on doing much more, figured I'd just start one thread, and continue with this one forever. I'll throw a lot of stuff I've done already on this first, then update when possible. so...sorry if you've seen some stuff before, it's all going to stay here now.
This is because Mitch asks questions about everything I have previously posted about... :wave:
YJ shackles-
This is NOT at ride height here, slopes about 45* back.
I did this in an effort to get my rear end to work as well as the front end. First thing was to move the shacke out of the "box" to get as much swing as possible. I picked YJ style shackles because I could go with a larger bushing, and picked boomerang shackles because I'm a loser and thought they looked cool, absolutely no benefit to them over straight shackles in this setup.
The bracket is bolted into stock position, then stich welds around the box.
I use RE 4.5" (RE1462) springs. I removed the smallest leaf, and added the largest "non-eye" spring from a stock XJ upcountry pack. I may have lost .5" of lift, but then I put on higher profile perches, so it's all even. This gave me the correct ride height, softer springs, but a little less load capacity..which is fine, I shouldn't carry that much crap anyway.
Next section is to deal with spring wrap!
YJ shackles-
