View Single Post
  #20
Old March 24th, 2008, 15:46
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Re: help oring filter adapter , still leaks after instaling new orings?
"further back on the connector" ??
Do you mean it's leaking where the oil filter attaches? Because those are the only two places it should leak, unless there's a crack in the actual adapter or it's coming through the adapter bolt. If it's leaking from the filter end, I seriously recommend pulling the filter and making sure you don't have two gaskets stuck there.
Jim www.yuccaman.com
