All 4 turn signals stopped working
Maz
LaCanada, CA
Hi all;
Search didn't turn up anything related.
Just last week, I checked all the lights on my '89 XJ and everything worked.
Yesterday, when I started her, none of the 4 front and rear turn signals worked. I checked all the fuses under the dash, and they were all OK. I cleaned the grounds at the dip stick, firewall and by the windshield washer bottle. Still no signal light.
I haven't checked the bulbs yet, but was wondering if one burnt out bulb would cause all 4 not to work.
What else should I check? Is there a common ground to all 4 that would cause this?
Any pointers or wags would be very much appreciated.
Thanks .. Maz
Maz said:
Hi all;
Thanks .. Maz
how about the flasher? Find out where that's at in yours and maybe swap it with the emergency one.
I forgot to check the flasher. What do you mean by the "emergency one"?
I upgraded to the electronic type than the regular. I find they last me longer. Maybe as they can handle more lights. A wee bit more to buy, but I really don't like to be without my turn signals, or hazards.
Easy way to check, do your hazards work? If so, switch the flashers. If your turn signals work and your hazards don't, you know it's the flasher.
There are two flashers - one for turn signals, and a separate unit for the hazzard lights. You can, in a pinch, use the hazzard flasher to restore the turn signals. Typically, you'll know what you lose a bulb because one side will flash at a different rate than the other.
Old-style "thermal" flashers are tank circuits tied through a relay, and depend on the resistance of the bulbs to set the flash rate - changing the number of lights changes the flas rate (and that's why those units act silly when towing.)
The electronic flashers are nice (the flash timing is set by electronics rather than external resistance, and also do well for towing and can handle more lights) but they don't give you the "warning" that you've got a light out and you've got to stay on top of that yourself. Having said that, I've switched over to electronics (Tridon EL12 - about $9 each) and I also do monthly light checks anyhow.
If you are willing, I'd suggest the electronic units, they DO last longer and they don't care if you tow, change to LED lights, use "slave lights" when you flat tow or dolly tow, or pretty much anything else. Of course, Murphy's law being what it is, I never lose a flasher as long as I keep a spare (thermal) in the glove box.
Quick test - hit your hazzards. If they work, buy a new flasher.
5-90
5-90
I hit the hazard flasher and it worked, all 4 signal lights. I replaced the "turn signal flasher can" with the "hazard flasher can"; turn signals still don't work.
Is the problem in the steering stalk? When using the turn signal lever, the one-click sound is still there.
I appreciate the quick replies guys. Any other suggestions before I take her in for a steering column tear-up?
Thanks .. Maz
5-90 said:
PM me a reminder in a couple hours or so and I'll see if I can give you a couple tests to isolate the problem.
5-90
Will do and standing by. Thanks very much. Did you get my PM this morning?
-Maz
Interesting. Hopefully 5-90 can isolate it. In the steering column, there's the small mechanism that mkes the turn signals work, and the two little springs that turn them off after turning. Only thing I know of in the column. [but I'm pretty new to this and still learning lots] The springs tend to go after a while, and have to be replaced. One of mine went about a month ago, so just did both, but I don't know if that mechanism could cause your problem at all. I know the spring going will still allow the signal lights to work.
cykaaro said:
.....but I don't know if that mechanism could cause your problem at all.
Yeah, I agree, I am not sure either.
Went to store and bought a replacement canister (AKA "can" as Remi called it :) )anyways. It didn't fix the problem. I am thinking bad wire, but where?
-Maz
Update and resolution;
I was probing around the fuse box and under the dash with my multimeter, following Jon's (5-90) instructions (mega thanks 5-90) when for some reason I tried a fresh 20amp fuse for the Turn/Backup fuse. What do you know, the blinkers started working. I was very surprised since the old fuse looks perfect and you can see pic of it. I guess a fuse can go bad and still look OK.
Pic:
http://pg.photos.yahoo.com/ph/entanik/detail?.dir=5967&.dnm=7e48.jpg&.src=ph
