View Single Post
  #5
Old July 12th, 2019, 07:52
Tony the Liger Tony the Liger is offline
Re: Unexplained coolant loss, but mechanics thinks the head is fine. ???
Originally Posted by VAhasnoWAVES View Post
the problematic head crack usually results in mixing. i wouldnt jump right to suspecting that.
if you are losing it but not seeing it... its burning off before you can see it. its either making its way into the cylinder or burning off the block. id suspect head gasket either way.
I'm going to send an oil sample to Blackstone Labs, too, fwiw.
