View Single Post
  #24
Old August 17th, 2020, 20:38
Anak's Avatar
Anak Anak is offline
Stranger
Re: Best battery clamps w accessory studs
That is certainly an improvement over using the clamping bar the way those things are designed to be used.
Is it possible to get those in separate positive and negative designs? It looks like you are pretty much all out of clamping range on the negative side.
