View Single Post
  #23
Old August 17th, 2020, 18:58
ehall's Avatar
ehall ehall is offline
Re: Best battery clamps w accessory studs
Best I have found so far is the plain old battery terminals, with a few simple mods
Remove the cheap bolts that hold the clamping bar, install 1"+ bolts from the bottom to create studs, and then use locking flange nuts or wing nuts to secure the leads. Then run a bolt through the clamp holes for the battery post, for additional mounts and for clamping a charger.
my '91 beater rebuild
