Well my problem started Sunday, I was driving home from work and the jeep was doing fine, untill I rolled up to a stop light and the whole jeep felt like it was rocking, I looked down at my rpm gauge and it was borderline zero. So I gave it some gas to keep from cutting off. Well It never would cut off at lights the rest of the way home. So the next morning before work I and looked for any loose vacume lines because this has happened to me once before, but I saw none.
So running late I had to leave, about half way to work at one light it completely shut off, so I cranked it back up. Then one stop light away from work it shut off again, so I cranked it but this time it reved up around 2000 rpm and wouldnt go back down. So I pulled in the parking lot and turned it off, started it again and it still was reving around 2k.
After work I came out and it cranked up and was ideling fine untill it got hot then it stated rough again. So I stoped off at Auto Zone and got a new distributor cap and button and a new set of spark plugs. Changed these and it seemed to idle a little better. I went swimming and drove when I pulled into my grandfathers driveway it cut off again, so I recranked it and it shut off imedatly, also on the way home it was a pain to keep running, having to hold the break and gas (auto) at the same time.
Finaly once I got home it shut off again. So if anyone has any ideas I would be thankful.
