jdxj
- Colorado Springs
Will the brake rotors and callipers form a LP D30 out of a 01 work on a HP d30 from a 94? Thanks. :dunno:
splitz said:If you're going to change out knucles, why not go WJ?
(BTW I have no idea what i'm talking about, so I don't know if this mod works on all Dana 30s)
That is my plan eventually. But I'm still saving up parts.:looney: Main reason to swap axels is my 01 has a LP( low pinion) and the 94 has a HP for better driveline angles.
On that thought though will the bearings from either work with the WJ Knuckles
cal said:Very high cost
Very high complication
Figure $600 and the requirement of a good welder, if you use some used parts. If you go all new, its over a grand.
jdxj said:Ya but if you do that then your steering won't work and new steering
Ends
Tie rod
Drag link
trackbar relocate bracket
Adds Up quick.
