    More Information - Join/Renew
2000 Cherokee 4WD 4.0 Backfiring through Intake
stonedv8
Decatur, Al
I searched and found only one other with a similar year model, and his was throwing O2 sensor codes but he never posted again what may have fixed his issue.
This is/was my daily driver so I am hitching a ride with the wife until I can resolve this. Adds about 3 hrs to my schedule as she goes in to work earlier than I do.
Anyways, 2000 Jeep Cherokee 4WD 4.0 motor with about 130k on the odometer. Going home about 500 yds from my house the Jeep just started backfiring VERY loudly through the intake/throttle body. Can rev it up and the backfire goes away but it runs rough. Will crank and idle at normal rpm's except for the gunshot backfiring.
One code had popped and it was P0122 TPS, so I checked voltage going to it and it was 5v like book stated, so I replaced the TPS. No luck.
Cleaned TB by spraying cleaner in it while running, keeping it running and not letting it stall out. No luck.
Checked all the wiring, while running move wire harness.
Pulled Cam Position Sensor and smelled burned and since it felt like a timing issue I replaced the Cam Sensor. No luck
Had replaced plugs about 3 months ago with NGK's so those are fine. I pulled coil packs/rail and checked firing. The boots all fire fine.
Checked Fuel pressure at the rail, its reading 49psi at idle.
Checked for vacuum leaks by spraying the TB cleaner all around, no fluctuation in idle or revving.
After replacing both the previous sensors I have disconnected the positive terminal and touched it to the negative for 30 seconds and did the PCM reset steps.
I am at a loss, I have scoured the interwebs because I hate posting problems in the luck that there are others out with the same issues, but again from when I have found similar issues was on earlier XJ's that had distributors, as this one does not I have no luck.
I would suspect the O2 sensors. Test the O2 sensors.
O2 sensor service life is about 100-150,000 miles. They become slow to react and can cause bucking, stalling, or backfiring. When they go, you often see an unexplained drop of 30-40% in your gas mpg's.
Pull all the plugs and do a compression test. If one cylinder is way low, then look at it closer. If all 6 are low, then perhaps a timing chain jumped. Sometimes a backfire is an intake valve not fully sealing or closing, and when the plug fires, if the intake is not sealed closed, it will backfire into the intake manifold. A compression test is quick and dirty, and it rules out a bunch of items it compression is all good...
Pull the cam sensor drive (you will have to re align it when you reinstall it) and check the teeth on the cam and sensor drive. Before you pull it see how it lines up. Bring #1 up to TDC on the compression stroke, pull the sensor off and see if the hole in the drive rotor lines up with the hole in the drive body. It isn't uncommon for the drive to seize up and shear teeth off.
As stated, also check the MAP sensor and the vacuum line elbow going to the throttle body under it.
Always start your troubleshooting with the simple and logical stuff. O2 sensors, and for that matter any of the other sensors are routine maintenance items that you should expect to simply replace when they fail. The O2 Sensors and the Coolant Temperature Sensor are the only ones that will cause backfiring.
After you have checked and tested all the sensors, inspected the wire harnesses and wire plugs for corrosion, damage, and chafed or melted insulation, you might consider some less likely suspects.
Low compression or jumped timing chain are highly unlikely. Even a worn cam sensor drive is not likely, but it is easily inspected.
Do a full re-boot on the ECM.
This very simple procedure will erase the 1996-2001 “Adaptive Memory” stored inside the PCM and allow a new “Adaptive Memory” to be developed.
After performing this procedure the 1996-2001 PCM will re-learn and store into Adaptive Memory your engines performance characteristics.
Please perform these steps exactly as they are written, in the order they are written. This will cause the adaptive memory in the PCM to be erased and cause the PCM to go into Fast Learn Mode adaptive mode.
Disconnect the POSITIVE battery Terminal and touch it to ground ( not the battery negative terminal ) for 30 seconds. The engine block or the A/C compressor pump will work as a ground. (This is to discharge the PCM capacitors, which maintain the Adaptive Memory).
Reconnect the Battery Cable
Turn Ignition Switch to the “On” position but DO NOT start the engine
Turn Headlight “On”
Turn Headlights “Off”
Turn Ignition Key “Off”
The PCM Adaptive memory has now been flashed, or erased from the PCM.
When you start the engine it will be running off a set of pre-programmed tables that come with the PCM from the factory.
When you get the engine up to operating temperature the PCM will start to collect data for the “Adaptive Memory”.
The PCM will collect data for Adaptive Memory for the first 50 Warm-up Cycles.
Not true. The cam sensor can definitely cause back firing. Theoretically a failing CPS sensor can as well.
Turn Headlight “On”
I can't see anywhere in the wiring diagram where the headlight circuit comes anywhere close to the PCM. How the hell would that work?
The PCM doesn't know if the lights are on or off. I don't think that part matters, unless it has something to do with the PCM sensing voltage.
the only think I could think of would be to do that with the battery disconnected to put a load on the electrical system to drain any remaining voltages from the pcm caps (which touching the B+ cable to the block would do). But with the battery reconnected that would just turn the headlights on and off.
IDK, ask the Engineers at Jeep where the instructions came from.
I have done this and it does clear the PCM Adaptive Memory.
Again excellent advice.
I am at work, about to head home and will be borrowing a compression tester to do a test. Its quick and easy enough.
Also, thanks for the info again on reflashing the PCM. I had been grounding out the positive wire on the ground battery wire, so it seems I wasnt following the correct advice. That I can remedy as well.
So, tonights schedule is a compression test, MAP and vacuum test and O2 sensor test.
Also, from Tim_MN advice he stated the coolant temp sensor could cause backfiring, I did notice a large scale/gunk buildup in my coolant cap, (kinda noticed as I was scratching my head on what else to check the last couple of days, a flush is in order) so I may have junk on that sensor. Strange that could cause backfiring, but theres another test as well.
Ok, compression test was good on all 6.
Pulled MAT sensor, cleaned it as it was pretty fouled.
Pulled MAP and checked vacuum. Looked good on vacuum. Did volt test to MAP 5v (good). Did volt output while idling and at WOT. No output whatsoever, stayed at the 5v in. Did not fluctuate at all. Looks like failure so far.
Found another test for the MAP online that had a 3rd test to test if the MAP was grounding, which showed to connect black test lead to #3 pin on MAP connection then run red test lead to positive side of battery. If it shows 12v then its bad, 0v then it could be good. Well it showed 12v, so looks like its the MAP.
Too late tonight to get one, but I work tomorrow so will send wife out and check back after work.
Fingers crossed.
Are you certain you are checking the correct wire?
Looking at the plug side, with the clip up. The left one is 1) sensor ground, the middle, is 2) sensor signal to the PCM, the right one is 3) 5v supply. You should be testing #2, the middle one. Its should read some where around 1.5-2v with the engine running at idle.
Well crap, no I am not.
According to the Chilton manual I was supposed to check voltage output at #1 and #3 when running. But now upon reflection your suggestion makes perfect sense, as #1 and #3 would be power into the MAP and #2 would be signal out of MAP.
Hmm, so far this is the 4th error I have found in the manual.
Really starting to dislike this manual.
So no luck today. Most Auto parts places have the MAP sensor, but they want $80+ for them.
I found I can get them all day long for $15 shipped on ebay.
I know they may not be the same quality, but since I am still not 100% sure on my issues, I dont want to drop $80 until I know the exact malfunction.
I dont mind spending money for piece of mind but until I know my problem, I am still in diagnosis land.
I am off on Sunday and Mondays, so I will hit up a few pick and pull Salvage yards around my area and grab all the sensors I can get my hands on, they run about $5 each.
As far as the previous question, yes I can crank it and it will idle all day long, just the backfiring sounds like a machine gun going off in the intake manifold.
Can rev it up some to about 3-4k rpm and the backfiring goes away but it runs sluggish.
I would would check the cam sensor first, but since you said it happens shortly after you start it the O2 sensor is a good option. Check for wiring problems by the drive shafts first. On start the O2 sensors aren't read right away. After about a minute they are hot enough for the PCM to read them.
I did, I replaced the Cam position sensor, TPS, and Engine Coolant Sensor with brand new ones already.
But yes, the Crank Position and O2 sensors are on tap to be tested tomorrow, and then Monday I will be heading to a you-pull it salvage yard for any sensor I can get my hands on, they said about $5 each if I pull them, so gonna grab what I can and start swapping out.
