View Single Post
  #4
Old October 19th, 2020, 07:28
Anak's Avatar
Anak Anak is offline
Stranger
Re: Vehicle security
Geo-location is going to cost you. Probably will have a monthly service charge as well.
Impact sensor and door switches are standard equipment on the low end of alarms. It is just a matter of wiring. You should be able to tie into the dome light circuit for the door switches.
A kill switch on the fuel pump is a good idea.
I run a steering wheel club. Not that it can't be overcome, but because it is an obvious obstacle that needs to be overcome. Thieves are looking for the easy victim. Don't be easy. It may also help that I have a stick shift. Probably confuses at least half of the dirtbags.
