View Single Post
  #2
Old December 6th, 2016, 09:06
RCP Phx RCP Phx is offline
Re: AX5 interchange between early and late
You have the idea backwards, you need to install a longer input gear on the x-case. I don't believe you can change the transmission output shaft without total dis-assembly.
