90xj06
- Peabody, MA
1988 XJ AW4.
I have a leak at the front most fitting on the transmission to the hard line. at the quick disconnect.
is there an oring kit for this. because i pulled it apart once and replaced it with a spare used hard line and that lasted about a month. and now its leaking again.
when i pulled it apart it had 2 orings and a plastic sleeve that fell out. what order does it go?
or is there an easy way to just go with a barbed fitting.
