View Single Post
  #13
Old March 6th, 2019, 09:13
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Lifted Daily Drivers
Originally Posted by techno1154 View Post
Your 01 XJ have similar specs to my XJ,... when I add a bumper and winch is should drop at least 1/2" from the 4 1/2 it is now. What valving are the 5165's. I think 255/70 valving are good out back but the front could use something with less drop out/rebound.
I'm running 255/70, front and rear. 90% of my driving is on the pavement where a little softer ride is appreciated.
You might want the 360/80 valving, if a stiffer front end is desired.
What I used, Bilstein 5165
Front 11.3", 23-187717, 255/70
Rear 9.8", 25-177510, 255/70
'https://www.shockwarehouse.com/news/bilstein_5165.cfm
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
