My build... long arm lift, JK axle swap, stiffeners, whole 9 yards
I used a synergy jk tre on the knuckle and then a synergy xj/Tj tee in the pitman. No ream required. As for the rear brakes I used stock jk soft lines to the xj block. Got the bend out of the stock lines to that nickel copper lines. Tried to replicate the stock lines as much as possible. I'll try and see if I can get you a picture
Sweet thanks man and I didn't know about that synergy stiuff, I'm probably do that instead for steering. I do have a dropped pitman arm already
